05-14-2022 10:31 AM
i’m having trouble with the chromecast cec settings to control my denon avr (current model, supports google assistant). power on works perfectly, however neither volume nor input will work. i’m not concerned about getting in-n-out working, but the volume is frustrating. i can set it to work via ir, but i’d really like to be able to control it through the app.
i’m sure it isn’t an issue with the av receiver as i have other devices that have no issues with cec.
does anyone have experience fixing this?
thanks in advance!
05-18-2022 05:33 PM
Hi bri_,
Thanks for reaching out. I want to dig deeper into this.
A few questions: Were you able to control the volume using your Chromecast Voice Remote? Can you see your Denon AVR under the remote and accessories section for volume setup? Where is your Chromecast plugged into, is it on the TV or AVR? Can you tell me what app would you like to control the volume, is it the Google Home app or a different app?
Jennifer
05-21-2022 05:37 PM
It's me again. How's it going? Still need help?
Jennifer
05-22-2022 06:04 PM
Hi bri_,
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
05-22-2022 07:20 PM
Hey, thanks for your response! I am able to control it so long as I set up the remote to use IR, not CEC. The Chromecast is plugged into the AVR, and I'd like to use the Google Home app to control the volume.
05-28-2022 06:56 PM
Sorry for the late response. Could you try to plug in the Chromecast to your TV instead and try again? Also, please check the info below to see how you can configure it and control the volume:
Jennifer
05-31-2022 06:56 PM
I wanted to check back in to see if the troubleshooting steps shared help. Feel free to reply to this thread if you still need help.
Jennifer
06-01-2022 06:59 PM
Hi bri_,
I haven't heard from you in a while so I'll be locking this thread if there’s no update within 24 hrs. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
Jennfier
06-03-2022 10:10 AM
Hey there!
We haven't heard back from bri_, and it's been a few days, so I'm locking the thread. As always, feel free to make a new thread if you have any more questions or concerns.
Thank you for your help, Jennifer!
Jeran
