08-24-2025 07:35 AM
I would like to create an automation that starts a timer on a different device. I have tried device.command.TimerStart but it looks like Nest Hub 2 does not support that. So I continued with assistant.command.OkGoogle and set the device to the living room while issuing the command from the hallway (Nest speaker).
Unfortunately, despite setting the device to the one in the living room, the Nest speaker always starts the timer itself. How do I fix that?
Best regards
Sven
08-27-2025 04:54 PM
Hi sven25,
Thanks for posting. I'm sorry to hear about the situation that you are experiencing with the automation with the timer that you are trying to set with your Nest Hub 2nd Gen and Nest Speaker. I appreciate the information provided. Don't worry; I'll be happy to share more details with you. In this case, the best option for your automations is to check the Developer Center for further assistance.
I hope this information helps.
Jenny
08-30-2025 04:23 AM
Thanks. Unfortunately, the Dev Center does not seem to help here.
