05-19-2025 03:54 AM
If you ask Gemini about linking an action to the calendar it suggests you can do this using a "standard" automation. however that option doesn't appear to be there.
Is there any way of doing this?
05-19-2025 04:28 AM
The only way I know of doing this is with the Google Clock app, but an alarm has to be dismissed before an Automation can commence.
05-19-2025 06:44 AM - edited 05-19-2025 06:45 AM
Might be a way to do it via Google Automations Script Editor with the assistant.event.OkGoogle trigger.
GH ASE = home. google.com then left side of screen select automations
Out of that starter you really are left with time.schedule but if I remember right that is more about time of day vs a calendar.
Will test it out first approach later today.
05-22-2025 04:29 PM
Hi @Andybrad,
Thanks for reaching out to the Google Nest community. I'm sorry you've been experiencing liking actions to the calendar with Gemini. I'm glad to share more details with you.
It is best that you get in touch with the Google Assistant Help Community; they can provide you with the right information and troubleshooting steps to fix your Google Assistant issue.
Feel free to keep us posted if you have more questions.
Gabriela
