02-25-2025 07:31 AM
I am trying to add a 4th point in an additional room to a 3 point mesh network in my house. The 4th point is plugged in and flashing blue. When I get to the final step on the Google Home app ( adding WiFi point to WiFi mesh) it’s failed multiple times. Please advise.
02-26-2025 05:24 AM
I had this same issue setting up a new Wifi point on an Android device, but when I tried setting up with an iPhone it worked seamlessly. So if you're using an Android tab or phone to setup, you should consider using an iPhone.
03-01-2025 05:57 PM
Hi Richkos,
Thank you for reaching out to the community! I understand you're attempting to add a fourth point to your existing three-point mesh network in another room. I know it's frustrating when the device repeatedly fails to add. I'm here to help! To gather more information, I'd like to ask the following questions:
Let me know if you have any additional information; it’ll be helpful.
Juan
06-25-2025 11:14 AM
Can’t add factory reset google wifi to my existing 3 point mesh network using google home. Have iPhone 16 pro. Entered setup network and setup code but device couldn’t find network. Ideas?
07-23-2025 12:00 PM
my new device is a "Google Wifi" that looks just like the units I installed several years ago. I tried to set it up wirelessly. The parent point is only one room away, only 1 wallboard is in between. I don't know a "switch" is
