04-29-2023 05:25 PM
Hi all, our Daiken Airconditioner was always connected to our google home from its inception a year ago. We are now finding that even though google home shows the device to be connected, google nest is saying it looks like that device isnt set up yet. We are in Australia, I know we had trouble with the radio stations last couple of weeks but that was rectified, is there another problem with other devices?
04-30-2023 01:22 PM
Hi @shimmas
I had issues with the Daikin Airco's once with Google Home, but removing them and then adding them as a new integration did fix it. 🙂
04-30-2023 01:58 PM
Thanks RXShorty, but the aircon was working fine all year with google home, used the command last week even. But this week google is saying can't be found. I deleted it to try to reconnect it but now google can't find the air conditioner. The air conditioner works perfectly from the Airbase app and I have checked the internet connection all are good. Not sure if its a Daikin or Google issue.
05-02-2023 04:45 AM
A bit more to follow up, I am now receiving the following error
The parameter "state" must be set in the query string.
05-09-2023 11:39 AM
05-12-2023 01:07 PM
Hi shimmas,
Have you tried the steps above for your Daiken Air? Let me know if that did the trick or not so we can try something else.
Lovely
05-13-2023 01:13 PM
Hey shimmas,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. We'd be glad to help you further so if you still need assistance, feel free to start a new thread.
Lovely
