11-20-2023 09:09 AM
When someone ring the doorbell, I receive a notification on my phone and my Google Nest Hub Max is showing the doorbell video.
Both device are configured in French. The fast response on my phone are in French, but they are in English on my Nest Hub Max and my setup is really in French.
How can I fix that?
11-24-2023 11:28 AM
Hi DuFF1,
Thanks for reaching out and letting us know about your Google Nest Hub Max concern. Do you have multiple languages added to your Google account? If so, try to remove other languages and just leave French, then reboot your Google Nest Hub Max and observe if it makes a difference.
Juni
11-24-2023 03:33 PM
Hi!
i dint have multi language in my Google account. Only French.
11-28-2023 10:35 AM
Hello DuFF1,
Let’s further look into it. Kindly get the software version of your Google Nest Hub Max. Swipe up from the bottom of the display > Settings > Device information. Then, do a manual reboot on your Google Nest Hub Max by unplugging it from the power outlet for 2 minutes.
Alex
11-28-2023 12:00 PM
Version is 54.103.7.577294944
11-30-2023 10:33 AM
Got it. Try to configure the Nest doorbell Quick Responses in the Google Home app. Let us know if that helps.
Alex
11-30-2023 07:46 PM
spoken language was already in French. But after unplugging my Nest Hub Max for 2 minutes, it’s now in French.
12-05-2023 08:35 AM
Hey DuFF1,
That’s good to know! Thanks for keeping us posted. Should you have other questions or concerns about your Google Nest Hub Max, you know where to find us. We’d be happy to help.
Alex
