08-28-2022 11:32 AM
How do I take back control of my Google Home account when my son took control? I own the Google Wifi access points and my son set the system up through the Home app. He now has control over my WiFi, my Google Home app and refuses to let us in to use the WiFi. He locks us out of the WiFi though the app when he is angry. Everything is in my name and I pay the bills but I have no ownership. I need help resetting the home app even though he controls
11-02-2022 01:47 PM
Hi aswier38,
That certainly hasn't been easy for you ― if only your son allows you to be added as a home member then from there you can partially gain control. But an invite is needed, which in this case, is impossible since you want sole ownership and want it back. The only way left is to factory reset your WiFi routers to revert it back to its default and original settings. That way, you can set it back up on your Google Home app under your account.
Check out this guide: Factory reset your Wifi device, Set up Google Wifi and Set up Nest Wifi Pro or Nest Wifi.
Keep us posted.
Dan
11-05-2022 02:04 PM - edited 11-05-2022 02:04 PM
Dan
11-06-2022 01:11 PM
Hello again,
Dan
