08-01-2023 11:45 AM
Example show below, would like Google to show temperature and humidity or temperature instead of humidity. If you Ask Google what the temperature is, it has that information.
08-02-2023 05:10 AM
Regarding your request, if you ask Google for the weather, it will usually provide information about the temperature, humidity, and other relevant weather conditions for your location. Google's responses may vary based on your location and the specific weather data sources it uses.
08-22-2023 01:02 PM
Did you even read the question?
2 weeks ago - last edited 2 weeks ago
I have the same issue in Android Home application for sensors from linked SmartLife account: it shows only humidity on cards but voice asistant can talk a correct value of temperature from sensor by it name. I cannot find answer anywhere. It is definitly a bug but googlers are ignoring this issue.
