09-27-2022 08:49 AM
Can you have multi Google nests in one home to control different rooms?
09-27-2022 11:40 AM
Depending on your HVAC setup, if you have a standard furnace/AC setup , having thermostats in multiple rooms won't do much. Depending on the generation of thermostat you can get the extra temperature sensors , which might work better for you
10-03-2022 11:06 AM
Thanks for reaching out to Google Nest Community forum!
@Ashepherdson, thanks for sharing and I appreciate your help.
@Janetkidson, I wanted to check and ensure you are good to go. If you have a Zoning type system, you can install multiple Nest Thermostats on one home. Check this link on how it works. Also, Nest Temperature Sensor would work. You can program your Nest Thermostat to utilize multiple sensors at various times of the day and select which sensor operates it.. Here's a quick link.
Please let me know if you have any other questions.
10-06-2022 11:11 AM
Hello Janetkidson,
I just wanted to see if you still needed help. Please let us know if you have any other questions or concerns.
10-10-2022 09:54 AM
Hello there,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Nest Thermostat and we'd be glad to assist you further.
Princess
