06-16-2023 04:01 PM - edited 06-16-2023 11:52 PM
We built the Google Home script editor to give you more control over your home automations (announcement post). We are still in the early days of the script editor, and we highly value feedback and ideas from our community to shape its future.
You can use this post to:
How do I submit an idea? Can I submit more than one idea?
To submit an idea, simply click the "Reply" button below this post and add your idea in the following format:
We encourage you to submit as many ideas as you like, but please use one comment per idea so that it's easy for others to vote on your ideas.
How do I vote for an idea? Can I vote on more than one idea?
To vote for an idea, simply click the "Kudos" button next to the idea that helps you with your use case. Please use your votes thoughtfully so that we can clearly understand what matters to you the most.
Will my idea be implemented? Will the top-voted idea be implemented?
We will do our best to prioritize what is important across our entire community and look at feedback across many channels throughout the product cycle. We will very actively use your feedback in our prioritization exercise, but cannot make any guarantees or promises that you'll see your idea/feedback implemented into the product. That said, we will do our best to address the pain points and problems our community is trying to solve.
We look forward to hearing your ideas!
Prafulla Rawal, Senior Product Manager, Google Home
07-13-2023 06:47 PM
First of all, a huge thank you for your feedback and ideas! The engagement here has truly exceeded our expectations, and we couldn't be more grateful for your participation.
As mentioned above, we cannot make any guarantees or promises that we will implement every idea, but we are actively considering all of this feedback as we prioritize future development.
In the meantime, we encourage you to keep sharing your ideas and upvoting the ideas of others.
Thank you again for your time and input.
10-20-2024 05:28 PM
Thank you for this example.
are you referencing a Nest cam Zone within this script ? such as
Nest cam name "Front yard"
Nest cam zone name " Driveway"
10-20-2024 05:46 PM
The Front Yard is just the "Room" that the camera is located in within the Google Home App... When I set it up about a year ago you couldn't pick zones. I haven't checked to see if you can do that now or not cause everything works pretty good as is.
01-31-2025 11:40 AM
I have put in a request to access the zones in the script.
Not sure why they have left out a tag for the 4 activity zones that are available for out Nest cams.
I use the 4 zones daily. It separates events in garage, from driveway, from front of house and from street. It also allows me to ignore the rest of the area.
‘for those not using defined activity zones they can be very helpful.
11-08-2024 11:28 AM
Idea: Allow Google Nest Wifi Devices on the network to be "set as the priority device" on the network using only voice input
12-31-2024 06:50 PM
Add the ability to overide a device type.
Also add radiator commands, because for example Heatzy defines the type of its thermostats as "radiators" which limits what can be done with them on Google Home.
01-07-2025 12:31 PM
I'd like the ability to have the Assistant turn on a light when a condition is met, but then turn it off after a set amount of time.
For Example, when the door bell rings, turn on the porch light and turn off 10 minutes later.
01-07-2025 03:48 PM
That can be made using the action time.delay.
All actions are run in sequence so you can add a time.delay action between turning on and turning off the light defining the time you want the light to be on.
01-31-2025 04:33 AM
Could you elaborate one how that’s done?
I’m new to script editor and have added the condition of after sunset and before sunrise when the doorbell rings the light comes on but I cannot figure out how to set the time delay to turn the light off. I’m new sure where to put the “time.delay” and any other script that goes with it.
cheers.
01-31-2025 05:09 AM
actions:
- type: device.state.OnOff
state: on
is: true
device: Lamp 1
- type: time.delay
for: 10min
state: on
is: false
device: Lamp 1
It's simply a list of actions.
In this example you have a 10 minute delay between lights switched on and off again.
01-31-2025 03:34 PM
Hi Pat,
thanks for your reply.
under actions I don’t have the “device.state.onoff” I only have the “device.command.onoff” but it will not allow me to add the “time.delay” keeps coming up as an error.
01-31-2025 03:42 PM
metadata:
name: Doorbell and porch
description: when the doorbell rings after 20:30 and before 05:00 turn on the porch light and after 5 minutes turn the porch light off.
starters:
- type: device.event.DoorbellPress
device: Doorbell - Front door
condition:
type: time.between
before: 05:00
after: 20:30
weekdays:
- MON
- TUE
- WED
- THU
- FRI
- SAT
- SUN
actions:
- type: device.command.OnOff
on: true
devices: Porch Light - Front door
- type: time.delay
for: 5min
on: false
It only has the errors from the “- type: time.delay”
01-29-2025 10:07 PM
Idea: Allowing the use of more than weekly scheduling
Using script editor there seems to be a lack of scheduling options.
Right now there only seems to be a weekly schedule when I would like to automate notifications to tell me what bin it is one week and what bin it is the next.
Adding in a more complex scheduling system to allow for bi weekly/bi monthly ect. scheduling.
01-30-2025 01:48 AM - edited 01-30-2025 01:49 AM
You're right, weekly is too narrow, monthly would be nice, for summer or winter routines etc.
Concerning your use case, why don't you set up a Google calendar "Bins" that you fill with the specific dates for your area?
That's what I did. Everyone who has rights to that calendar receives customizable notifications.
(Filling the calendar is quite easy in my area because the department provides an ics file I can easily integrate, but you can of course set up bi-weekly dates or whatever is necessary.)
01-30-2025 02:03 AM
I have set it up on the calendar but I was wondering if there was a way to get it to communicate with my Google Hub to send an announcement at the certain date and time in case I’m not on my phone when that notification that comes through, but the automations on google home don’t allow for the precise scheduling.
05-06-2025 04:03 AM
Idea: Arithmetic expressions in offsets
Current limitation: it's only possible to add static offsets, such as +15min or -1hour (and only for sunrise and sunset)
Example automation:
05-06-2025 04:13 AM
Idea: Offsets for all Time entries
Current limitation: it's only possible to offsets to the keywords sunrise and sunset
Why: extremely useful in conjunction with arithmetic offsets
Example automations:
05-06-2025 04:27 AM
Idea: Add date.between condition
Current limitation: Despite Date being a valid unit, it cannot be used for the time.between condition that only accepts time
Why: Many automations are dependent on the season, month or date
# Run during Christmas season
type: date.between
before: 01/08
after: 11/30
# Run only on January 1st
type: date.between
before: 01/02
after: 12/31
4 weeks ago
idea: weather forecast as a starter
example: seasonally turning my thermostat off/on when the average forecast temperature for the next 7 days drops above or below 16 degrees celsius.
a week ago
Currently you can only include one condition. Having the ability to include multiple IF > THEN statements, and grouping AND OR conditions would significantly increase the power of automations.
a week ago
Expanding the triggers, conditions, and actions would be helpful. For example, you can turn on the lights when a camera detects a person at night, and you can include a delay to turn lights off after a period of time. It would be nice to have the lights turn off 15 minutes after the person is no longer detected.
