Sensor temp/humidity shows only humidity when creating routine (automation) in google assistant
Tari
I have sensors, all works fine, google home shows everything like should be, but when trying to automate and use sensor value as a trigger google assistant shows me in routine just humidity and no temperature.
case: Trying to start heating if temperatur falls below certain value. But there is a bug in assistant I believe and it is mission impossible while no temperaure value in routine designer.
7 REPLIES 7
Tarmo
I got similar problem. I have temp-humidity sensor (Nedis-sensor, connected by Lidl hub).
The decide is only showing the temperature in Google Home.
If I try to create an automation, only humidity is shown.
Lidl app is showing both.
Wanted the trigger heating based on temperature, but seems not to be possible.
Tari
This automation works for setting the temperature, but could you write a code for turning the AC off when reaching a certain temp (ie bellow 23 degrees)? I have been trying but it won't let me because it says that [OnOff] con [action.devices.types.AC_UNIT] are not allowed at the moment.
Hello I have the same problem I can't turn off the air conditioner with the temperature sensor "OnOff] con [action.devices.types.AC_UNIT] are not allowed at the moment." Did you manage to get around this problem in any way?
Tari
I was able to automate it in https://home.google.com via web script, in this case it is possible to use temperature. Scenario tested and worked.
But in mobile app environment it is stil not possible.
Piotr1983
Devlikin
Can you please show me your script?
