11-11-2025 06:26 PM
Just got the updated Nest and have been having so much trouble getting it to heat! I am confused about the temperature which says 70 and the “inside temperature “ says 64. My house is cold. I never had this problem with the old one.
Any help would be appreciated.
Peggy
11-15-2025 02:30 PM
Hello @Jhy310,
Thank you for posting in the community. I understand you recently installed an updated Nest Thermostat and are having trouble getting your house to heat and that you've seen a temperature difference where the thermostat is set to 70 degrees, but the "inside temperature" displayed says 64 degrees. I am here to help you get your heating working correctly and consistently.
To properly diagnose this and understand why your thermostat is showing two different temperature readings, I need to gather some specific details about your device and setup:
Once I know which model you have and where these temperatures are displayed, we can move forward with checking your wiring configuration and system settings to get your heat running.
Kevin
11-28-2025 06:46 AM
That's a common frustration with the updated Nest. The key is that the main display shows your target temperature (70°), while the "inside temperature" is what the sensor is actually reading (64°). This discrepancy often points to a placement issue. Is your thermostat on an interior wall away from drafts, direct sunlight, or heat sources like electronics? A cold exterior wall or a sunbeam from a window can trick the sensor. For homes with significant drafts from windows, improving insulation can help stabilize the ambient temperature. A solution like a window film from window tint can reduce cold spots near the thermostat, ensuring it reads the room's true temperature.
