01-27-2025 10:53 AM
I have a Nest Floodlight that, when motion triggered, I have an automation that turns on several other lights. What I'm missing is the ability to turn those additional lights off after a set period of time, say 3 minutes.
I'm able to accomplish this with motion sensors, but haven't be able to do so when the floodlight turns off. Any help would be appreciated.
Thanks!
01-30-2025 02:19 PM
Hi tfresh911,
Thanks for reaching out. I understand that your Google Nest camera floodlight does not turn off after the set period of 3 minutes. I'm happy to assist you! Please follow these steps:
Check the motion sensitivity:
Remove and re-add the timer setting:
Let me know if this helps!
Manuel
04-23-2025 08:07 AM
Some casinos create the illusion of choice, and some really give you freedom. Crown Casino Online belongs to the latter: from the number of providers to the types of games - everything is available and works without interruptions. Australians will be comfortable - the interface is intuitive, there is no need to adjust anything.
