rutines home català
Alex801
com pot ser que l'idioma del so si que pot ser en català i les rutines de HOME no?
2 REPLIES 2
kcruzgonzalez
Hi @Alex801,
Thank you for posting in the community. I understand that you're having trouble with Google Home Routines, and I fully understand the importance of having a feature available in your preferred language. Let's work together for a solution.
You've brought up a very important point. It's true that while Google Assistant supports Catalan for many voice commands and sound functions, some more complex features, like Google Home routines, are still in the process of being implemented for a wider range of languages.
Currently, routines are available in a limited number of languages. Google is always working to expand language support across all of its features, but this development process can take time.
The best way to make your voice heard and help prioritize this feature is to send feedback directly to the Google development team.
You can do this easily through the Google Home app:
  1. Open the Google Home app.
  2. Tap your profile icon in the top right.
  3. Select 'Help & feedback.'
  4. Tap 'Send feedback.'
  5. Explain in detail why routines in Catalan are important to you.
I hope this information helps you understand the situation. If you have any other questions, please do not hesitate to ask.
Kevin
Alex801
perfecte, ja he enviat el que em comentes per mig de Google home, gràcies per l'ajuda 😉
