05-31-2022 10:49 AM
How do I contact Nest Aware technical support to obtain another copy of the QR code and/or key code configured for my device? The Original QR code and key have faded and can not be scanned nor read to reconnect my device to my current network. the Help Center, though I'm sure they were earnest in their attempt, was no help at all.
Thanks.
05-31-2022 11:08 AM
I'm just another customer, but the only way I know of to contact Google Nest Support is via their online contact link: https://support.google.com/googlenest/gethelp?hl=en
I've seen other posts here where customers have been unable to read or scan their QR code, and there seems to be no resolution posted.
Maybe one of the Google Nest Community Specialists will read your post here and provide you with a way to resolve your faced QR code.
06-03-2022 05:18 AM
No. I have not received the answer that I did not know I would have an issue in obtaining. Though, I've paid my monthly subscription, I can not use my product without being able to scan the QR code or enter the code key. I'm trying to reach technical support or any department that may be able to forward a copy of the existing QR code and/or key or reconfigure another QR code and key for my device. Please, assist at your earliest convenience.
06-10-2022 10:31 AM
I am so sorry to hear that you do not have access to your QR code in order to install your device! I can imagine this has been quite a frustrating situation, and I know I would feel the same way. Unfortunately, I do have to let you know that without the QR code which can be found on the back of the device, and on the packaging, you cannot install it without the code. Do you still have the packaging?
06-10-2022 12:29 PM
How's it going Brad,
06-10-2022 12:34 PM
I am relieved to hear that you have the packaging! You can find the QR code near the barcode. It's a square shape, with various black and white shapes/dots. Also, if you cannot locate it, do you see a Serial Number? You can also use that to finish installation, or to provide to Support if this doesn't work out so they can look it up for you.
06-13-2022 01:38 PM
06-16-2022 10:06 PM
Thanks for the help, Brad.
Archie
