8 connection help
Abconn97
Is this wiring system compatible?
i believe the O/B/W2/E may be adjustable.
Hello Abconn97,
Thanks for posting with your thermostat wiring diagram. I'd be happy to take a look into this for you.
It appears that you have a heat pump system with emergency heat. I see two wires corresponding to C and B. Usually, these are common wires. To be sure, could you check and share a photo of your system's control panel with us to see how these wires are labeled?
EdwardT
Hi Abconn97,
Edward
EmersonB
Hello everyone,
@Abconn97 just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
I appreciate the help, Mark and Edward.
