02-26-2022 01:37 PM
We have the Nest calling for heat but the AC turns on. Anyone have any ideas?
02-27-2022 05:25 AM
Was this unit just installed? I would have to assume it was just recently installed. Check the wiring. Sounds like you have the wire hooked up to the A/C and the heat. Thermostat doesn't know what's on the end of the wires. It just provides power to that specific pin.
03-06-2022 01:53 PM
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Thanks for your help, Somewhatsavy69.
Ryan
03-09-2022 02:56 PM
Have a great day.
Ryan
05-25-2022 05:23 PM
Hope this helps!
Kind regards,
Ryan
