Any way to adjust aux heat to start at -25c/-13f?
Proyan
I've updated my heat pump and since it can heat to -25c/-13f, i would like to change the adjustments so that the aux system starts at -25c/-13f but it only goes down to -12c/10f, any way to change that??
2 REPLIES 2
PylonSquelch
I just posted the same thing here :
https://www.googlenestcommunity.com/t5/Nest-Thermostats/Start-alt-heat-below-12c-10f/td-p/130476
Hopefully someone will respond to my post.
Ryan_G
Hope this helps!
Kind regards,
Ryan
