05-17-2023 11:50 PM
Our nest resides in our home in the US and we are currently vacationing in Europe. When i set temp through Alexa to, say, 70 degrees F will nest automatically switch from the heater / heating system to our AC / cooling system as a function of the ambient temp in our house? If not, how do I enable this remotely in iOS?
05-25-2023 11:02 AM
Hello Daddymorebucks,
Thank you for taking the time to let us know about your inquiry.
When your Nest Thermostat is set to Heat/Cool Mode, which can automatically switch between heating and cooling as needed, Alexa manages it in a slightly different way. For instance, your thermostat's lower and higher settings should be set to the 68–75 degree range if you ask Alexa to adjust the temperature to 72 degrees.
Feel free to let us know if you have more questions in mind.
05-28-2023 12:56 PM
Dan
05-29-2023 03:34 PM
Hello again,
Dan
