BOILER KEEPS RUNNING, TIMER NOT WORKING
STRATH
Hi Everyone
I have just moved into a new house with a nest thermostat installed which is all very new to me. The problems seem to be many to me but I am a bit lost with it all. Firstly when I set a temperature on the thermostat manually it doesn't stop at that temperature I set and just keeps climbing above it, then when I turn it down or off the boiler keeps running and I have to turn it off manually. The other problem I have and more important is I have set the timer but the heating never comes on, which isn't great on cold mornings. Any help would be much appreciated as its driving me crazy.
Thanks in advance.
moralesvicente
Hello STRATH,
Thank you for taking an interest in our community. I'm sorry to hear you're having trouble with your thermostat. because the boiler continues to run past the desired temperature when you manually set it, even if you turn off the boiler, it keeps running, and that the heating timer isn't working as expected. Don’t worry; I’m happy to help.
I'd like to ask you a few questions in order to gather more information about the concern and find the best way to find a solution.
  • What type of thermostat do you have? For your reference, check out this article: How to tell which Nest thermostat you have
  • When did the issue start?
  • What other strange symptoms have you experienced since the trouble started?
  • Is there a wiring report or error message on your thermostat and/or app?
  • What is the type of boiler you have?
Any more information you may give will be beneficial.
Daniel
