10-19-2021 05:34 AM
Our nest thermometer is now giving a warning message that the battery is low. It has only been in use since June. Should I need to replace the battery this often or does it indicate a wiring or system problem?
10-23-2021 07:46 AM
What model of thermostat do you have? Nest Learning Thermostat, Nest Thermostat E, or the newest Nest Thermostat (2020?
10-28-2021 01:56 PM
Hey MegH,
I wanted to follow up and ensure you are good to go. Please let me know if you have any questions from here, as I would be happy to take a closer look and assist you further.
Thanks so much davidking, for the helpful link as well!
11-02-2021 09:51 AM
Thank you, Here is a copy of what I sent to davidking:
So sorry. I have been away and just back in town. I have a Nest that was purchased in 2020. It is not a E or a Learning thermostat. It has been turned off quite a bit as we have been traveling and don’t want leave the air conditioning on ( even set to a higher temperature). Could that have caused the problem? We also have two thermostats to replace the old ones that were in the house. One is for heating and one is for air-conditioning. Could that be an issue. Not too hard to change the batteries but just want to make sure there is not an issue which is going to cause problems down the line.
11-02-2021 09:53 AM
11-10-2021 10:36 AM
Hey MegH,
If you are running into your device not staying charged, there is a chance you may need to install a C wire or a Nest Power Connector to the device. Do you mind me asking if you know if you have a C wire installed already? Are you seeing any specific error codes on the device? Please let me know, so I can look into the issue further and ensure your device is staying charged.
11-16-2021 01:40 PM
Hey MegH,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
11-17-2021 05:53 AM
Thanks for your continued follow-up. I do not know if there was a C-wire issue or not as this was installed by the person we use for heating and air conditioning checks. This particular thermostat runs our air conditioning so we currently have it turned off. Please feel free to close the thread. If we continue to have difficulty next season I will ask our HVAC person about the C wire and follow up as necessary.
11-17-2021 10:20 AM
Hey MegH,
I understand where you are coming from, and I am sorry again for the trouble you have run into. Per your request, I will be locking the thread at this time. Please feel free to create a new post at any time if you have any questions or future trouble from here.
