Best Thermostat won’t recharge
GABoy
I installed my nest about 6-8 months ago. Everything has been working fine until now. It began disconnecting from the WiFi. Now the battery on the nest will not recharge. I’ve even taken the nest off and recharged it with the usb. When I install it back on the wall it mostly gives a black screen with a red blinking dot. It will cut on periodically and run for a minute or two and then shut right back off. Attached is a photo of how it’s wired up. Please help
Hi GABoy,
Thanks for posting in the Google Nest Community forum — I appreciate you for being a step ahead of us. I'm sorry for the delay. A few questions: how long did you charge your Nest Learning Thermostat? Also, in what country are you located?
