Chang from dual fuel to electric only
gamitch11
During setup, I mistakenly selected dual fuel.  My house is total electric.  I have a heat pump with auxillary  heating.  How do I change from dual fuel to just electric?
gamitch11
Oh I forgot, I have a Nest gen3 thermostat.
The easiest way is to reset the thermostat to factory default and set it up again.
gamitch11
Figured it out.  Thanks.
Hello folks,
Thanks for the input, @Patrick_Caezza.
I'm glad to hear you've sorted it out, @gamitch11. It looks like we can consider this one complete, so I will lock the thread within 24 hours unless I can help out with anything else.
