02-14-2022 08:17 AM
My building is installing new Fan Coil Units. They come with a Ecobee Smart Thermostat but I have two Nest Learning Thermostats. All the manufacturer of the new fan coils can tell me is to ask if the Nest Thermostats are compatible with the following specs: 24 volt (I think the answer is yes), three speed fan (yes), two pipe fan coil. Its this last spec that I can confirm. Does anyone know if my new fan coil system will be compatible with the Nest Learning Thermostats I current own?
02-21-2022 02:59 PM
Hi there Sincjc,
Thanks for posting here and we're sorry about the delay.
Google Nest thermostats are designed to work with most 24 V systems, even older systems. For us to further check, you could attach a photo of the current wiring setup and we'll check it's compatibility with Nest Thermostat.
I hope to hear from you very soon.
Ryan
06-11-2022 05:48 PM
Hope this helps!
Kind regards,
Ryan
