Compatability
Mauricio3
I am trying to see if a Google Nest is compatible with the current wire setting I have on the picture above.
That worked. Thank you so much.
Mauricio3
Seems my like I have O terminal for reversing Valve
Your system is compatible with any of the Nest thermostats
Give this wiring a try.
White - W2 to W2 or W
Green - G to G
Orange - O to OB or */OB
Blue - B to C
Yellow - Y to Y1 or Y
Red - RC to Rc (jumper to R not needed)
The "or" is for the Google Nest Thermostat
MelbaDT
Thanks for taking the time to answer to this, Patrick_Caezza.
Mauricio3, glad to hear that your question is answered and that your Nest thermostat is now working as it should. Feel free to reach out again if you need more help in the future, we'll just be here.
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
