Compatability
blackraine04
I am trying to see if a Google Nest is compatible with the current wire setting I have on the picture below. Thanks. Thermostat wiring.jpg
7 REPLIES 7
I can't read what the labels are. Can you post them here
That's the problem... there aren't any
There appears to be something there as I see what looks like E2 next to the white wire.
If there is nothing there, look at the terminal block on the control board in the furnace/air handler
blackraine04
You are correct... I just looked again... it says R, C E1 and E2
Any help would be greatly appreciated
MelbaDT
Thanks for responding here, Patrick_Caezza.
blackraine04, it seems that this was already answered and solved on another post. If this is for another system, let us know so we could check on it further.
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
