11-02-2021 07:20 PM
Multiple times in the past few weeks my Nest thermostat disconnects from WiFi. I have reset our router, restarted the Nest and checked battery levels. All are correct. The battery today was at 3.704. Each time I have used a charger directly to the Nest for about two hours. When I put the Nest back on the base it connects to WiFi no problem.
I am also noticing the temperature is about 3-4 degrees off. The Nest says 72 degrees. An external thermometer is telling me it is around 68 degrees. I need some assistance please.
11-04-2021 01:38 AM
This seems to be a common and recent issue ... not entirely sure what the cause it but it's very annoying to have the set the house temperature to 25 because technology is failing us.
12-29-2021 11:43 AM
Hey all,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
12-29-2021 01:09 PM
Hi Jake,
I kept having issues with it, tried to reset and even opened it up to see if there was anything obvious. I ended up buying a new one that is working as normal. Thank you for getting in touch.
Kind Regards,
Guilherme
01-06-2022 11:09 AM
Hey Gee,
Glad to hear everything worked out and you are good to go. With that being the case, I am going to lock the thread at this time. If you run into any questions from here, please feel free to create a new post. Have a wonderful rest of your day as well.
