Cooling Mode issues
DrJJ
I cannot find the cooling mode on the app or on the thermostat. Can somebody please help? I’m melting!!
Thank you!
zoeuvre
Hi DrJJ,
Thanks for posting here Community, and I'm sorry to hear about the situation. If the cooling mode option doesn't appear on the app or on the Nest Thermostat, I advise you to turn off your power breaker to your HVAC system, then remove and then reconnect your Nest Thermostat's Y/Y1 wire. Let us know if that works.
DrJJ
Thank you zoeuvre! I did what you suggested and reloaded the thermostat. It’s working now.
I appreciate your help!
zoeuvre
Great! I'm glad to hear that everything has been sorted out. In the meantime, I'll go ahead and lock this thread within 24 hours. If you run into any more questions in the future, please feel free to create a new thread.
