Cooling fan
Squarediamonds
Why can’t I get the cooling fan to turn off
Hello Squarediamonds,
I'm sorry to hear you're experiencing difficulties with your Nest Thermostat's cooling fan. Let's troubleshoot together to find a solution.
Firstly, ensure that your Nest Thermostat is set to the desired temperature and cooling mode. If the fan continues to run, check the fan settings on your thermostat. You can find these settings in the Nest app or on the device itself. Make sure the fan is set to "Auto" rather than "On." When set to "Auto," the fan should only run when heating or cooling is actively in progress.
If the problem persists, you may need to check the wiring of your thermostat. Ensure that the wires are properly connected and that there are no loose connections.
I hope this helps, and let us know how it goes.
