10-04-2022 04:47 PM
My thermostat is located about a foot or so below my field of vision, when I first installed it I could see and read the display perfectly, be it when I did the software update I can no longer read the display unless I bend down and I am directly in front of it. How do I get it back to the way it was?
10-08-2022 09:49 AM
Hi Djslick,
Thanks for reaching out. I'm sorry to hear that you're having an issue with the display of your Nest Thermostat. If you have a Nest Learning Thermostat, you can go your thermostat's Settings > Brightness. Press the ring to adjust the brightness of your Nest thermostat's display. You can select low, medium, high, or auto.
Edward
10-11-2022 09:59 AM
Hey Djslick,
Edward
10-12-2022 10:17 AM
Hi Djslick,
Edward
