Do I need a yellow wire? My system doesn't have one
PJC7
I don't know if we did something wrong or if our system isn't compatible. Our heat works and we can get the cooling to come on... but the fan to our AC won't turn on at all. The AC unit doesn't make any sound like it kicks on. AC worked fine last season before we installed the Google nest.
PJC7
zoeuvre
Hi PJC7,
Thanks for reaching out to us, and I’m sorry to hear about the situation. No worries, we'll check this out.
I see that your Nest Thermostat 2020 is a heating-only system, which therefore won't be able to control any cooling since there is no dedicated cooling wire that is connected to the Y terminal. A few questions: Is your Nest Thermostat 2020 newly installed? Who installed your Nest Thermostat? Also, could you send us a wiring photo of your HVAC control board where the other end of your thermostat wires are connected?
zoeuvre
I wanted to check and see if you managed to see the information I shared. Please let me know if you have any questions from here. I would be happy to assist and make sure you are good to go.
zoeuvre
Hello PJC7,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
