Does it work for replacement?
Troglodyte
Hello Everyone,
     So I recently want to change the old thermostat to Nest, but how to conect those? So Do I connect Rh Rc in one R? or? Can anyone help me?
Yes, your system is compatible with the Nest 3rd GEN Learning Thermostat or any Nest Thermostat.
Give this wiring a try.
Red - RH to Rc (jumper to RC not needed)
White - O to OB
Yellow - Y to Y1
Green - G to G
Black - C to C
MelbaDT
Thanks for your detailed answer, Patrick_Caezza. This is greatly appreciated.
Troglodyte, I'm checking back in if you still have some questions about your thermostat.
Melba
MelbaDT
How's your Nest thermostat now? Let us know if you need more help.
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
