E260 Error in Hot air, gas fired furnace
DominickS1960
I have a Honeywell Thermostat with wiring as depicted. I hooked up the Nest and keep getting E260 error. The Blue wire is Common but the no power to Y continues. It is a heat only, forced hot air system. Any ideas?Thermo Wiring.jpg
6 REPLIES 6
Houptee
Are you sure about this is Heat Only system?
The Yellow wire to Y is the signal to turn on the Air Conditioning system outside unit.
If you do not have AC and only Heat then just connect.
Red wire or might be brown hard to tell from your pic, to RH
Blue to C
White to W1
Green to G
Do not connect the Y if you do not have Air Conditioning.
Then tell the Nest the system type during setup.
Thank you for the tip! They had central A/C once upon a time. I will try again without Yellow... Stay tuned.
Jeff
Hi DominickS1960,
I just wanted to follow up and see if you were able to try out the suggested steps and to see if they were able to clear things up for you. If you've tried that out with the yellow wire and things still aren't working correctly, please let us know.
Jeff
thank you for your help and follow up. The suggestion work perfectly.
Jeff
Good to hear, DominickS1960.
I'll go ahead and mark this resolved for you, but before I do, I wanted to see if you had any additional questions. If so, just let me know.
Jeff
Jhonleanmel
DominickS1960, awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread now. Feel free to create a thread if you have other questions or concerns.
Mel
