Entry Key with Hyphens won't enter
NBRDoug
We just moved into a new house which has the Nest Learning Thermostat installed.  I have it hooked up to the Wi-Fi no problem.  However, when adding to the Nest App the entry key supplied has a hyphen in it, like 999-BIRD.  Nothing I do allows the hyphen to be entered on the entry key page of the app.  Anyone experience this and have a work around or update?
brian_a
I also have this same problem and haven't found a solution. Does anyone have any ideas?
