Error 44 no power connected.
Anand08
Hi, last night on my thermostat it shows error E44. now thermostat off automatically and not getting turn on and alao furnace not getting on.
6 REPLIES 6
RXShorty
Hi @Anand08,
This sounds like there is a powering problem with your Nest thermostat.
Could be a wiring problem. 🙂
Anand08
How can i solve this problem?
An E44 error falls into the Nest 2nd Gen Learning Thermostat error code range.
I did find a reference that the E44 error means
  •  No power wire detected, R Wire required
  • Your Nest either has wires that aren't fully inserted into the connectors or has tripped an internal fuse. If an internal fuse has tripped, your nest may need to be replaced.
Check and make sure all of the wires are fully inserted into each terminal and that the bare copper is straight and shiny.
Jeran
Hey there Anand08,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Thank you for helping out on this thread, RXShorty and Patrick_Caezza!
Jeran
aatienza
Archie
aatienza
Hey everyone,
Archie
