Fan Speed and Temperature Set Point
pasvasconcelos
When my script run at 20:30, just the AC turn on for heating, but no fan at "Auto" mode or temperature at 22C... but if I click at "play" button in home app, these 2 configurations are activated. why?
metadata:
  name: AC Deitar Inverno Miudos
  description: Entre o Por do Sol e o Nascer do Sol, Ligar o Ar condicionado se inferior a 20C
automations:
  - starters:
      - type: time.schedule
        at: 20:30
        weekdays:
          - MON
          - TUE
          - WED
          - THU
          - FRI
          - SAT
          - SUN
    actions:
      - type: device.command.ThermostatSetMode
        thermostatMode: heat
        devices: Miúdos - Miúdos
      - type: device.command.SetFanSpeed
        fanSpeed: Auto
      - type: device.command.ThermostatTemperatureSetpoint
        thermostatTemperatureSetpoint: 22C
RenzJ
Hi  pasvasconcelos,
Thanks for bringing this up here in the Google Nest community. The fan should run together with your Cooling or heating system.  I wanted to look deeper into this before we conclude. Please answer the following:
  1. Are you from North America or Europe?
  2. What type of Nest Thermostat do you have or plan to have?
  3. Send us a picture of your HVAC control board wiring.
  4. What is the make and model of your HVAC?
Renz
