08-22-2023 05:22 PM
The fan speed slows down intermittently on my single stage furnace while running the ac. I have 2 furnaces and the issue follows the thermostat. The nest controls do not have a fan speed setting option. This issue is not present with my prior thermostat (not a nest) so the issue is not the furnace blower.
08-22-2023 08:49 PM
@JackIV ,
Do you have a multi speed fan set up on your Nest Learning Thermostat? If you have a single G wire then there nothing the Nest Thermostat can do to slow the speed down. If, you have a multi speed system, the software only changes the speed when you select a feature like “Cool to Dry”.
So why not share a little more so we can help you. What is your system configuration including uploading a picture of your Nest Backplate showing the wire that are connected.
AC Cooling Wizard
