02-10-2022 05:13 PM
The fan has been running all day even when the AC is not on. Can’t find a way on the thermostat to turn off the fan. Only display I see is to set the timer for 15 minutes but it wouldn’t shut off. The only way to turn it off is the breaker. Is there a compatibility issue?
02-11-2022 03:25 PM
You could do some troubleshooting to help:
05-13-2022 11:47 AM
I have the same problem. Everything us wired correctly. When I remove the G wire the fan finally shuts off.
02-16-2022 02:40 PM
@sporfrog, thanks for the help. What you've listed should cover the details that we need to check on the OP's concern.
@Th284, please let us know if you still need help by replying to this thread and we'll be glad to assist you.
Ryan
05-13-2022 11:49 AM
I have the same problem. Everything is wired correctly. When I remove the G wire the fan finally shuts off.
02-20-2022 08:50 AM
I just wanted to follow up and see if anyone is still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
04-06-2022 06:17 PM
Hey Ryan - I need help. I’m having the same problem - my fan runs non-stop. I detached the G wire and the fan still runs. It only stops when I turn off the breaker
04-07-2022 07:32 AM
If your fan is running all the time even when the G wire is disconnected, it most likely is the HVAC unit malfunctioning. If you pull the thermostat off of the base and the fan still runs, it definitely is the HVAC unit.
06-20-2022 11:31 AM
Thanks for sharing this here in the Google Nest Community.
I'd like to check in here if you're still having the same issue with the fan running continuously. Have you tried to remove the Nest Thermostat from the base like what sporfrog has mentioned? Is it still running even if it is being removed? Also, let us know which Nest Thermostat you're using and if you have a G wire connected to it.
Thanks for your help, sporfrog.
Ryan
09-19-2022 07:52 AM
02-23-2022 09:55 AM
Have a great day.
Ryan
05-20-2022 08:03 AM
Hello Ryan I’m having the same problem, I just installed the nest thermostats few days ago, it’s was working well, till yesterday, the fan is running a least for the last 24 hours. I’m trying to turning it off trough the app unsuccessfully. HELP HELP I’m about to get the nest off and re install the old divise
04-16-2022 02:18 PM
We are having the same issue with fan running non-stop. It worked fine until a granddaughter messed with the thermostat and the heat setting was at 84 when I discovered it. We have tried a full reset and it is still running even with the fan turned to "off".
07-10-2022 02:24 AM
Ryan
07-13-2022 11:50 AM
Thanks for checking in. Turns out the problem was with the AC unit, not the Nest. Our granddaughter had messed with the Nest so we assumed that is where things went wrong. She's off the hook!
09-13-2022 01:05 PM
I have started facing this issue about a month after installation of the Nest Thermostat with c wire adapter. The fans continually runs if the thermostat is plugged in. For a month I had no problems.
 when I remove the thermostat of the mount plate the fan stops. I also got the hvac unit inspected and the personal told me that it’s a fault with the nest and also checked that adapter if it’s sending power to the fan using the c wire adapter. Every looks good
is there a resolution for this ?
09-25-2022 05:45 AM
Hey everyone,
Thanks for reaching out here in the Google Nest Community.
You could check this link for more information on how to change the settings and schedule your fan with your Nest Thermostat.
I hope it helps.
Ryan
09-28-2022 05:51 AM
Ryan
09-29-2022 02:33 PM
Hey everyone,
Did anyone have any more questions or need any additional help? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
