07-04-2022 07:23 AM
Documentation says, while the thermostat is locked:
"Anyone can turn the thermostat’s ring to change the temperature within the range you’ve set"
It seems that this is only possible in HEAT -or- COOL mode not HEAT*COOL mode.
I see many post asking for this feature (temperature adjustment on a NEST that is in HEAT*COOL mode) but I do not find any resolution. This would be a huge feature for those of us with rental properties.
07-23-2022 01:27 PM
Will this issue ever be addressed?
Does anyone know of a product that will allow a renter to set a temp within a range (Heat or Cool required) and also run a schedule?
07-27-2022 09:09 PM
Hi Condo612,
Thanks for reaching out here in the Google Nest Community.
You can set the lock feature even in Heat-Cool mode. Check out this link to learn more.
I hope it helps.
Ryan
07-28-2022 05:48 AM
07-28-2022 07:41 PM
Hi Condo612,
Thanks for the reply.
Got it. You cannot change the temperature range or settings when you've set a lock within heat-cool mode. What you can do is to use the Google Home, Nest app or unlock the thermostat.
Another way to set your desired temperature is to set a temperature schedule or set your lock in heat or cool mode.
We'll take this as feedback and thank you for sharing it with us. It'll help us create a more helpful products in the future.
Ryan
07-28-2022 07:57 PM
Thanks for replying.
This seems like such a simple fix in the NEST firmware.
I truly hope is is included in a future firmware upgrade or perhaps the next generation of NEST Thermostats.
Thanks, Charles
07-31-2022 08:22 PM
Hey Condo612,
We appreciate your understanding regarding this matter. We are always looking for ways to improve our product and services.
Ryan
08-04-2022 06:09 AM
Ryan
08-04-2022 06:19 AM
I do not think the NEST Thermostat will do what I need.
Allow set-point adjustment within a range while lock in HEAT*COOL mode.
08-07-2022 04:31 AM
HI Condo612,
Thanks for the reply here.
We can only set a temperature set point when on heat or cool mode. We're always open to feedback and suggestions to make a better product and services.
We appreciate you sharing your thoughts here in the Google Nest Community.
Ryan
08-10-2022 06:15 AM
Ryan
08-11-2022 12:01 PM
Have a great day.
Ryan
