12-01-2023 05:09 PM
My heat pump only blows cold air. The Nest thermostat is set to heat but I only get cold air. During summer the cold air is good but now is too cold and I need the heat. I had tried many of the solutions offered from the google nest community and also from You-Tube but there are not positive results. The problem is the same: Not heat. Only cold air is coming from the vents. Outside weather is cold, the house is too cold and I need heat. Somebody told me to switch the thermostat to cold air to see if will come out hot but it came out cold. During summer everything is good. But now is cold and I need heat. Can somebody help me please? Professional help is very expensive and at my age, I cant afford it.
Thank you for your help and God bless.
Noris Fernandez
Orlando, Fl 32822
12-05-2023 11:52 AM
Hello confucio,
I'm sorry to hear about the issues you're facing with your heat pump. It's frustrating when your home isn't as warm as you need it to be. It's commendable that you've tried various solutions from the Google Nest Community and YouTube.
Here are a few suggestions you might consider:
I hope this helps and stay warm!
