Heat link issue
Danni33
Hi I've just had my thermostat replaced, but trying to connect to my previous heat link ? Is this possible without removing off wall etc ?
2 REPLIES 2
AlexD
Thanks for reaching out to us here @Danni33 . I would be happy to try and assist.
Generally you should be able to replace the thermostat without replacing the Heat Link but this also depends on why the thermostat is being replaced.
Could you confirm why you received a replacement for, what was going on with your old device, and what parts you received with your replacement?
Vladut
Hi there, just checking in with you. Did you manage to check the last message?
