10-01-2021 02:45 AM
Hi, I have 2 heat links installed, one of which has stopped working, the other is working perfectly. They are wired through the same fuse box and into the same boiler. The unit has no lights on, we've followed all suggestions found on the community site but nothing happens.
Please can someone help arrange a replacement ?
Thanks!
11-01-2021 05:11 AM
Hello, sorry didn’t see the notification of your first reply. This has all been sorted now and we received a replacement heat link. We had tried all steps mentioned and it was the unit itself that was faulty.
Thanks for following up!
10-29-2021 05:52 AM
Hello @slou20,
Thanks for reaching out. I'll do my best to get this sorted for you as soon as possible.
Here are some helpful troubleshooting steps:
Press the button on the Heat Link and check if you have any lights on it
Check if the circuit breakers and the switches are set to on
Turn them off and then back on
Press on the button again and check for LEDs
Could you also help me with some answers to these questions?
How many zones are present in the setup?
Cristian
11-01-2021 04:46 AM
Hi there. Just checking in. Do you still need my help?
11-01-2021 05:11 AM
11-01-2021 06:07 AM
No worries. Thanks for letting us know here. Don't hesitate to reach back out to us on any channel if you need any further assistance.
