Heat pump Nest thermostat wiring help
JsmithFin
Currently have a Braeburn thermostat with the following wiring (this was the setup when I moved in):
Rh: jumpered to Rc
Rc: red wire in
Y1: yellow wire in
G: green wire in
W1/E: brown wire in
W2: white wire in
O: orange wire in
B: not used
C: blue wire in
When I switched to the nest thermostat and plugged all the wires into their respectively labeled terminals, the nest system tells me I can only have one aux input (highlighting both W1 and W2 terminals as issues).
Looking for recommendations on which W is the correct one to use and if the other should be plugged into the * terminal.
Thanks!
luciaaa
Hi, @JsmithFin,
Thank you for posting in the community. I understand that wiring can be challenging, but we can work together to find a solution. I'm happy to assist you further.
To identify how to enter every wire, I would like to know:
Also, would you mind sharing a picture of the previous wiring configuration and the current one?
Feel free to ask any questions you might have along the way.
Ana.
Hi Ana,
For some reason I can't upload images (the option disappears after the message post box loads).
Currently using a Braeburn thermostat with the wiring configuration outlined in my original post:
Rh: jumpered to Rc
Rc: red wire in
Y1: yellow wire in
G: green wire in
W1/E: brown wire in
W2: white wire in
O: orange wire in
B: not used
C: blue wire in
I'm trying to connect to a nest learning thermostat. Removed the Rh jumper when installing the nest. The W1 cable plugged into W1 terminal and W2 plugged into the W2 terminal. This configuration caused an E83 error.
luciaaa
Hi, @JsmithFin
Thank you so much for your response and letting me know your thermostat model. I'm happy to provide you with further assistance.
Here's how to connect the wires:
Important: Before you begin, turn off the power breaker to your HVAC system.
  • Yellow wire connects to Y1.
  • Green wire connects to G.
  • Orange wire connects to O/B.
  • Red wire connects to Rc.
  • White wire connects to W1.
  • Blue wire connects to C.
  • Brown wire connects to * (star connector).
Ana
JsmithFin
I updated my post to add clarity and it was flagged as spam. Can I have the flag removed?
Link to post: (Heat pump Nest thermostat wiring help)
by JsmithFin
https://www.googlenestcommunity.com/t5/Nest-Thermostats/Heat-pump-Nest-thermostat-wiring-help/m-p/63...
Currently have a Braeburn thermostat with the following wiring (this was the setup when I moved in): Rh: jumpered to Rc Rc: red wire in Y1: yellow wire in G: green wire in W1/E: brown wire in W2: white wire in O: orange wire in B: not used C: blue wire in   When I switched to the nest thermostat and plugged all the wires into their respectively labeled terminals, the nest system tells me I can only have one aux input (highlighting both W1 and W2 terminals as issues). Looking for recommendations on which W is the correct one to use and if the other should be plugged into the * terminal.   Thanks!
This message has 0 replies
