02-22-2023 03:42 AM
This is the second time and a separate system where, for a heat pump, the thermostat trips the heater on when you put in air conditioning mode. The thermostat and system worked well for 3 years but a factory reset doesn’t do anything.
I replace nest thermostat with another nest for my other unit and it is something wrong with the unit.
how do I fix? Certainly it can’t be just to replace the thermostat.
02-27-2023 02:18 PM
Hi Forty12,
Thanks for reaching out. Let's sort this out:
03-02-2023 02:21 PM
Hi Forty12,
03-03-2023 02:53 PM
Hello folks,
Thanks for assisting, Jenelyn.
@Forty12, I'm checking in to make sure that you've seen our response. Please let us know if you have any additional questions or concerns before we lock this thread in 24 hours.
