Heat pump setting
Abreu20
Does nest thermostats has any pre set temp for aux heat to come on and help the compressor to heat when is 3 degree different from the target?
Houptee
You can set how you want the Nest to control the Aux heat.
Read this info to learn the options
https://support.google.com/googlenest/answer/9248719?hl=en#zippy=%2Cauxiliary-aux-heat%2Clearn-more-...
aatienza
Hey Abreu20,
Checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
I appreciate the help, Houptee.
Archie
aatienza
Archie
aatienza
Hello there,
Archie
