08-13-2023 01:41 PM
I had a Trane system with heat pump. The wires were set up as below but I saw there is no wire in O position. Also, there is one orange wire is left alone (I am not sure if that OB wire or not)
I installed my new Nest Learning and put the wires as below. However, the heat pump does not work. Is there any idea how to fix it? When the heat pump is on, the fan outside will run or not?
08-13-2023 03:35 PM
The way your old thermostat was wired makes me think you have a 2-stage gas furnace and a 2-stage air conditioner. Can you go outside and get a picture of the manufacturer label showing the model number please.
AC Cooling Wizard
08-14-2023 12:37 PM
Hi. This is information on the lable
Model#: 4TTX8048B1000BA
Serial#: 202917MX2F
08-14-2023 01:12 PM
Your outdoor unit is defiantly a 2-stage air conditioning condenser unit. Your gas furnace is 2-stage as well. Your stage 1 wire, the white wire, goes on W1 and the black wire is stage 2 and goes on W2. Your system is Gas Heat, Forced Air,
AC Cooling Wizard
08-14-2023 02:14 PM
Ok. Let me try. Thanks.
08-14-2023 03:22 PM
Do not forget the wire that was on your old thermostat Y2, needs to on the Nest Y2 as well.
AC Cooling Wizard
08-16-2023 03:20 PM
I connected all wires to nest but it said there is an error "E83: Heat pump can have at most one auxiliary heat wire".
08-16-2023 05:06 PM - edited 08-16-2023 05:17 PM
Your outdoor unit is an Air Conditioner It is not the heat pump. Your old thermostat was not wired as a heat pump it was wired as an 2-Stage Air Conditioner and a 2- stage furnace. Your wires on your nest should be:
Red wire to Nest Rh
Blue wire to C
Yellow wire to Y1
Tan wire to Y2
White wire to W1
Black wire to W2
Green wire to G
There should be no wire in the OB connector.
AC Cooling Wizard
08-17-2023 08:57 AM
Thanks. I will try again.
