Heat
Darci
My Neat will not kick on when temperature lowers below setting. Only way to turn it on is to turn off nest then turn it on then furnace will kick on and run.
gstoynev
This thread seems to have identified a software issue which disables the normal thermostat operation when safety temperature is reached. This is the post that describes the workaround and I can confirm it works:
https://www.googlenestcommunity.com/t5/Nest-Thermostats/Nest-not-calling-for-heat/m-p/63257/highligh...
I hope this helps
