03-26-2023 11:56 PM
Morning, my Heatlink unit has failed, I have checked Power and no issues, all fuses OK and boiler getting power.. I have held reset button for 30 secs and nothing. Hard reset nothing. Thermostat on wall now out of charge
Responses to your standard checks in CAPS below:
1) Does anything happen if you press its button for 30 seconds? - NO
2) In some cases the boiler will have an additional isolation switch which can turn off the power to both the Heat Link and the boiler. Can you try switching that off/ on again to see if anything changes? - TRIED THIS AND NOTHING CHANGED
3) Make sure the breakers are ON or the fuse board hasn't tripped. - CHECKED. NO TRIPS
Moreover, to have a better view over each of your cases, please help us with some answers:
a) How often do you experience the issue? - Started a few days ago and not been able to fix, constant issue
b) How long has your thermostat been installed for? - 2 years ago by a NEST Pro fitter "McCaffrey Electrical in Hamilton"
c) What colour is the Heat Link LED? - ALL LED's ARE OFF, EVEN WHEN PRESSING THE BUTTON
d) What is showing on the Nest thermostat display? - Nothing, battery dead.
e) Have you had any power cuts recently? - NO
f) Have you had any work done on your electrical or heating systems recently? - NO
g) How many zones are present in the setup? - ONE
h) Is there power present to your boiler? - YES
Many thanks
Chris Rough
04-03-2023 02:00 AM
Hi there @ChrisRough! I'm sorry to hear that you're experiencing this, but I'm here to assist you. I really appreciate all the troubleshooting that you've done, and we'll be able to move through this quickly. Can I send you an email with some instructions in order for me to be able to create a case in our system?
04-06-2023 04:24 AM
Hi there, just checking in, did you manage to see the message above?
04-06-2023 05:50 AM
Hi, I did reply to email but it was returned. Boxt came out and replaced the Heatlink - all sorted now thanks
04-06-2023 07:42 AM
Great! Please let me know if there's anything else I can help you with.
04-09-2023 08:19 AM
Hi there @ChrisRough! Just checking in with you. Did you see the message from my colleague?
04-09-2023 10:32 AM
Yes sorry. No more help needed.any thanka
04-10-2023 01:15 AM
If anything else comes up, feel free to open up a new thread. I will go ahead and close this one. Have a great day ahead.
