Help Nest Termostat 3rd Gen and thermostatics heads connected ? Help
ZZ007
Hello
Here is my installation:
Gas boiler with 6 radiators, five of which are equipped with an autonomous thermostatic valve on a single heating circuit.
Nest 3rd gen room thermostat installed in the living room.
T ° Day 21.
T ° Night 17
Everything works well technically except that the comfort is not ideal on two bedrooms.
There is always a 3 ° C difference.
I would have liked to know if it is possible to add thermostic heads connected directly to control the Heat Link unit connected to this boiler.
Ideally managed by the Nest app or conversely an app that manages its valves and capable of integrating the thermosat
If so, what brand or model of valve?
If not, do I have to create a parallel Tado or other type control circuit?
Thanks for your help.
Have a lovely day everybody
6 REPLIES 6
CristianC
Hi there. Thanks for reaching out. The thermostat is not compatible with thermostatic heads. You can still install them, but the thermostat won't be able to control them. If you want to control your heating in both bedrooms, individually, here's what you can do:
1. You can purchase a stand for the thermostat to move it around your home.
2. You can install a 2nd thermostat that will control the heating in your other bedroom.
Hope this helps.
AnaM
Just checking, do you still need help?
ZZ007
Yes..
Need the Best solution
AnaM
Hey @ZZ007,
The solutions to this issue have been presented by my colleague above, so there isn't anything else I can tell you in regards to this matter. Do those not work for you?
CristianC
Hello again. Just checking in. How's it going with your thermostat?
CristianC
It's been a while since this thread was last updated so I'll go ahead and lock this thread. If you're still experiencing problems, please feel free to start a new thread and we'll be happy to help.
