11-17-2022 08:38 AM
Ive been told that my thermostat is faulty as it wont connect to my wifi keeps coming up with error codes. Wanting 219 as a holding deposit so i dont loose the use on using it manually or im with out heating until i get an electrician to come out and put a normal switch on as there no over ride.ive 2 young children and dont have the money to just keep a side. Does anyone have any tricks they can tell me so i try those at least.
11-21-2022 05:49 PM
Hey Charli405,
Oh no! I'm sorry to hear that. Let's see what's going on ― what type of Nest thermostat do you have? Has your thermostat been paired before? If yes, were there any recent changes to your network and/or equipment? Do any of your other devices have issues with your Wi-Fi network? Also, what country are you located in?
You can check out this link for additional help.
Archie
11-24-2022 06:04 PM
Hi Charli405,
Edward
11-30-2022 04:03 PM
Hi Charli405,
Edward
